Brand
StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC 30 km
Quicklinx: 87PKWS00 Mfr#: ET90110SM302
£122.52 ex VAT
£147.02 inc VAT
Convert and extend a 10/100 Mbps Ethernet connection up to 18.6 miles/30km over Single Mode SC fiber. The ET90110SM302 10/100 Mbps Single Mode Fiber Media Converter SC (30 km) lets you extend a Fast Ethernet network (10/100) over single mode fiber, at distances up to 30 km (18.6 miles).
A cost-effective solution for connecting a 10/100 Mbps Ethernet (10/100Base-T) network to remote network segments over a 100Base-FX fiber backbone, the media converter is designed to offer a durable and convenient Ethernet to fiber solution, with an all-steel chassis, and simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC - 18.6 miles/30km over Single Mode SC Fiber (ET90110SM302) - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC single-mode
External
North America, United Kingdom, Europe
Cabling Type
100Base-FX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
30 km
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.6 kg
P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
100Base-FX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
30 km
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
1 x network - RJ-45 female , 1 x Ethernet 100Base-FX - SC single-mode female x 2
FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.6 kg
60 °C
10 - 90%
87PK StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC 30 km In Stock £122.52
87PK StarTech.com DC Power Adapter - 12V, 2A In Stock £13.92
87PK StarTech.com DC Power Adapter - 12V, 5A In Stock £45.71
Stock Status: In stock
