StarTech.com 1-Prt PCI Express Serial Card
Quicklinx: GVKHWS00 Mfr#: 11050-PC-SERIAL-CARD
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
17 In Stock
£36.07 ex VAT
£43.28 inc VAT
Add serial communication support to your desktop computer or Small Form Factor (SFF) system, using this serial card. RS-232 (DB9) support enables control and communication with a serial peripheral device.
  • Legacy Connectivity
    Install this card to enable the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The PCIe serial card is ideal for system upgrades in a wide range of applications for logistics, manufacturing, and freight sectors, and the IT industry, such as POS equipment, security systems, A/V installations, and more.
  • Connect with Ease
    The RS-232 card features 16C1050 UART support, 256-byte FIFO (transmit/receive), bi-directional speeds up to 921.6 Kbps, low-profile bracket is included for SFF systems, and serial port LED status lights. In addition, it supports Windows and Linux systems for maximum compatibility. 11050-PC-SERIAL-CARD is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com PCI Express Serial Card, PCIe to RS232 (DB9) Serial Interface Card, PC Serial Card with 16C1050 UART, Standard or Low Profile Brackets, COM Retention, For Windows & Linux - PCIe to DB9 Card (11050-PC-SERIAL-CARD) - serial adapter - PCIe 2.0 - RS-232 x 1
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
Ports
RS-232 x 1
1.8 cm x 6.5 cm x 6.7 cm
RS-232
Data Transfer Rate
921.6 Kbps
16C1050 UART
Yellow
Linux, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 10 / 11
Serial adapter
PCI Express 2.0 x1
PCIe 2.0
Ports
RS-232 x 1
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Status
256-byte FIFO
16C1050 UART
1 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
Low-profile bracket
Yellow
1.8 cm
6.5 cm
6.7 cm
Shipping Width
20.7 cm
Shipping Depth
14.4 cm
Shipping Height
3.8 cm
Shipping Weight
200 g
55 °C
5 - 95%
Protocol: RS-232
