The PEX4S553 4-Port Native PCI Express RS232 Serial Adapter Card with 16550 UART lets you add 4 RS232 (DB9) serial ports, using a single PCI Express expansion slot.
Based on a native single-chip design, this 4-port serial adapter card allows you to harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge-chip serial cards.
The RS232 Serial Adapter Card includes 4 half-height/low-profile brackets, allowing the card to be installed into almost any PC case, regardless of form factor.
- StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART - Low Profile Serial Card (PEX4S553) - serial adapter - PCIe 1.1 - 4 ports
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 1.1 x1
- 1.9 cm x 13 cm x 12 cm
- 80 g
- Ports Qty
- 4 ports
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 128 Kbps
- Processor
- 1 x MosChip Semiconductor MCS9904CV-AA
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter - 4 ports
- Form Factor
- Plug-in card
- Connectivity Technology
- Wired
- RS-232
- 128 Kbps
Processor / Memory
- Processor
- 2 x RS-232 - 9 pin D-Sub (DB-9) , 2 x RS-232 - 9 pin D-Sub (DB-9) (on bracket)
- Compatible Slots
- 1 x PCI Express 1.1 x1
- Included Accessories
- 4 x low-profile bracket
- FCC, RoHS
- OS Required
- 1.9 cm
- 13 cm
- 12 cm
- 80 g
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 5 - 85%
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 2 Port PCI Express RS232 Serial Adapter Card | In Stock | £36.09 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £155.21 |
StarTech.com 1-Prt PCI Express Serial Card | In Stock | £36.98 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £38.53 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £42.80 |
