Connect to, configure and remotely manage an RS-232 serial device over an IP network. The NETRS2321P 1 Port Serial to Ethernet Converter is an effective serial over IP solution that lets you connect to, configure and remotely manage an RS-232 serial device over a LAN. The RS-232 to Ethernet converter is designed to function seamlessly with your integrated serial ports, giving you the tools to communicate with remote RS-232 devices as if they were connected directly.
The adapter offers versatile browser-based or Virtual Com port software configuration for customizing the device to suit your application. The adapter also offers remote Telnet configuration and support for IP, HTTP, ICMP, DHCP, ARP, TCP and UDP protocols, while providing baud rates of up to 460.8Kbps.
With a sturdy aluminum enclosure and DIN-Rail or wall mountable brackets, the serial device server provides a durable remote serial interface for industrial automation, security, Point of Sale and many others.
Access your serial devices remotely
The versatile device server is designed to function seamlessly with your integrated serial ports, while offering baud rates faster than many other device servers (up to 230.4Kbps).The device server provides the tools you need to communicate with remote RS-232 devices as if they were directly connected. -
Flexible setup and operation
It offers versatile browser-based or Virtual COM port software configuration for customizing the device to suit your application. Plus, the software communicates directly with the device server, so it can be used in Virtual Machine (VM) environments if you have multiple VMs sharing the same set of hardware. The device server also offers remote Telnet configuration and support for IP, HTTP, ICMP, DHCP, ARP, TCP and UDP protocols. -
Aluminum housing provides durability you can count on
With a sturdy aluminum housing and DIN rail or surface mounting brackets, the serial device server provides a durable remote serial interface for industrial automation, security, Point of Sale and many other applications. -
Download the application software and manage your serial devices with ease
Download the StarTech.com serial control software from the Apple App Store, the Google Play Store, or the Chrome Web Store. The NETRS2321P is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 1 Port RS232 to Ethernet IP Converter / Device Server - Aluminum - Serial over IP Device Server - Serial to IP Converter (NETRS2321P) - device server
- Device server
- Form Factor
- DIN rail mountable
- Localisation
- North America, United Kingdom, Europe
- Data Link Protocol
- Ethernet, Fast Ethernet, RS-232
- OS Required
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
- Power
- AC 100/230 V
- 5.3 cm x 8.1 cm x 2.3 cm
- 295 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Device server
- 5.3 cm
- 8.1 cm
- 2.3 cm
- 295 g
- Enclosure Colour
- Black
- Localisation
- Form Factor
- Connectivity Technology
- Wired
- Data Transfer Rate
- 460.8 Kbps
- TCP/IP, UDP/IP, ICMP/IP, ARP, DHCP
- Remote Management Protocol
- Telnet, HTTP
- Status Indicators
- Power, transmit, receive, link/activity
- Flow control, DHCP support, wall mountable
- 1 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 100/230 V
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 90% (non-condensing)
- Designed For
StarTech.com Slimline DB9 Serial Gender Changer - F/F | In Stock | £4.96 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum | In Stock | £123.57 |
StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet | In Stock | £119.36 |
StarTech.com 2PT Serial-to-IP Device Server | In Stock | £179.10 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
