Brand
StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum
Quicklinx: 92PTWS00 Mfr#: NETRS2321P
10 in stock
£115.78 ex VAT
£138.93 inc VAT
Connect to, configure and remotely manage an RS-232 serial device over an IP network. The NETRS2321P 1 Port Serial to Ethernet Converter is an effective serial over IP solution that lets you connect to, configure and remotely manage an RS-232 serial device over a LAN. The RS-232 to Ethernet converter is designed to function seamlessly with your integrated serial ports, giving you the tools to communicate with remote RS-232 devices as if they were connected directly.
The adapter offers versatile browser-based or Virtual Com port software configuration for customizing the device to suit your application. The adapter also offers remote Telnet configuration and support for IP, HTTP, ICMP, DHCP, ARP, TCP and UDP protocols, while providing baud rates of up to 460.8Kbps.
With a sturdy aluminum enclosure and DIN-Rail or wall mountable brackets, the serial device server provides a durable remote serial interface for industrial automation, security, Point of Sale and many others.
StarTech.com 1 Port RS232 to Ethernet IP Converter / Device Server - Aluminum - Serial over IP Device Server - Serial to IP Converter (NETRS2321P) - device server
Device server
DIN rail mountable
North America, United Kingdom, Europe
Ethernet, Fast Ethernet, RS-232
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
AC 100/230 V
5.3 cm x 8.1 cm x 2.3 cm
295 g
P/N: SVA12M2NEUA, SVA12M5NA
Device server
5.3 cm
8.1 cm
2.3 cm
295 g
Enclosure Colour
DIN rail mountable
Wired
Data Transfer Rate
460.8 Kbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, ARP, DHCP
Remote Management Protocol
Telnet, HTTP
Status Indicators
Power, transmit, receive, link/activity
Flow control, DHCP support, wall mountable
1 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45
FCC, RoHS
External power adapter
AC 100/230 V
Software Included
Drivers & Utilities
60 °C
0 - 90% (non-condensing)
92PT StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.56
92PT StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.19
92PT StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum In Stock £115.78
92PT StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet In Stock £118.13
92PT StarTech.com DC Power Adapter - 12V, 2A In Stock £13.40
92PT StarTech.com DC Power Adapter - 12V, 5A In Stock £33.16
Stock Status: In stock
