StarTech.com 1 Port PCI RS232 Serial Adapter Card with 16550 UART
Quicklinx: 3ZRYWS00 Mfr#: PCI1S550
  • Windows 8 (32/64 bits)
Add an RS-232 serial port to your PC through a PCI expansion slot. The PCI1S550 16550 serial PCI card can be installed in a PCI slot to add one RS232 serial port - a cost-effective solution for connecting any new serial device or old legacy serial device, with data transfer rates of up to 115.2 Kbps.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, to your system, the 1 serial port PCI card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, Vista, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux.
A convenient easy to install solution, the PCI serial card can be connected in minutes through simple plug and play installation.
StarTech.com 1 Port PCI RS232 Serial Adapter Card with 16550 UART - PCI Serial Adapter - PCI rs232 - PCI Serial Card (PCI1S550) - serial adapter - PCI - RS-232
Serial adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
RS-232
Cabling Type
V.24
RS-232
Data Transfer Rate
920 Kbps
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
Plug-in card
PCI
Ports
RS-232
Wired
Cabling Type
V.24
RS-232
Data Transfer Rate
920 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1
Compatible Slots
1 x PCI
Plug and Play
Software Included
Drivers & Utilities
Limited warranty - parts and labour - lifetime
3ZRY StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.37
3ZRY StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £151.41
