Add a high-speed parallel port (EPP/ECP) to your desktop computer through a PCI expansion slot. This high performance PCI based EPP/ECP parallel adapter card can be installed in a computer PCI slot to add one IEEE 1284 parallel port to your PC. A cost-effective way to connect parallel devices to the computer, with data transfer speeds of up to 1.5 Mbps (up to 3 times faster than on-board parallel ports).
The adapter card supports EPP, ECP, SPP and BPP parallel communications, and is simple to install in virtually any PC. The card supports Windows Vista, XP, ME, 2000, 98, 95, NT4, DOS and Linux, plus IRQ sharing and plug and play capabilities guarantee convenient, hassle-free connections to any parallel peripheral.
A complete dual profile solution, the PCI parallel adapter card provides both standard bracket and low profile/half-height brackets for adapting to slimline or small form factor system applications.
- StarTech.com 1 Port PCI Parallel Adapter Card - Parallel adapter - PCI - IEEE 1284 - PCI1PECP - parallel adapter - PCI - IEEE 1284
- Parallel adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports
- IEEE 1284
- Data Link Protocol
- Parallel
- Data Transfer Rate
- 1.5 Mbps
- System Requirements
- Microsoft Windows 95/98, Linux, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / NT, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Parallel adapter
- Form Factor
- Plug-in card
- PCI
- Ports
- IEEE 1284
- Connectivity Technology
- Wired
- Parallel
- 1.5 Mbps
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female - 1
- Compatible Slots
- 1 x PCI
- Plug and Play
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - lifetime - carry-in
Customer reviews
Write a review for the StarTech.com 1 Port PCI Parallel Adapter Card here!
StarTech.com 1 Port Parallel PCI Card
Reviewed by John. Review Posted 23/07/2007
I bought one of these for my mother-in-law's new Vista PC. She has a parallel printer/scanner that she wanted to use and the machine didn't have any parallel ports. The physical install took about 5 minutes. The only fiddly part was finding the right drivers for Vista (they didn't come on the CD) but they are all there on startech.com's website. So, after about 15 minutes in total, there is now a reliable parallel port where previously there was none. Price is good too!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
