StarTech.com 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART
Quicklinx: 3ZRXWS00 Mfr#: PCI1S550_LP
  • Windows 8 (32/64 bits)
Add 1 high-speed RS-232 serial port to your low profile/small form factor computer with a PCI expansion slot.
This 16550 Serial PCI Card can be installed in a computer PCI slot to add an RS232 serial port - a cost-effective solution for connecting any new serial device or old legacy serial device, with data transfer rates of up to 115.2 Kbps. The serial card features a low profile/half-height bracket, suitable for installation in low profile/small form factor computer cases.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, to your system, the PCI Serial card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, Vista, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux. Saving time and hassle, the PCI serial card can be connected in minutes through simple plug and play installation.
StarTech.com 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART - serial adapter - PCI - RS-232
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
Ports
RS-232
12 cm x 5.5 cm
RS-232
Data Transfer Rate
920 Kbps
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Serial adapter
PCI
Ports
RS-232
Wired
RS-232
Data Transfer Rate
920 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI - low-profile
Plug and Play, CSA, UL, TUV, CB
12 cm
5.5 cm
Limited warranty - lifetime
3ZRX StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
