Add a 10/100/1000Mbps Ethernet port to any PC through a PCI Express slot. The ST1000SPEX2L Low-Profile PCIe Gigabit Network Card adds a 10/100/1000 Mbps compatible RJ45 Ethernet port to a PCI Express-enabled client, server or workstation, providing a convenient addition or replacement networking interface.
Compliant with IEEE 802.3/u/ab standards, and with support for 9K Jumbo Frames, VLAN tagging and Wake on LAN (WOL), this versatile Gigabit NIC/Server Adapter offers effective network performance.
The card comes pre-configured with a low-profile/half-height installation bracket and includes a standard profile bracket for installation in a wide range of computer/server chassis, regardless of form factor.
Efficient data transfer
Supports data transfer rates of 1 Gbps, ensuring fast and reliable network connections for enhanced performance. -
Compact low-profile design
Designed for low-profile installations, this network card fits well in smaller cases without compromising power. -
Advanced connectivity
Utilizes RJ-45 connector with support for 10Base-T, 100Base-TX, and 1000Base-T cabling types for versatile networking options. -
Robust operating range
Capable of functioning in temperatures from 0°C to 70°C, this network card can withstand various environmental conditions. -
Auto-uplink technology
Features auto-uplink (auto MDI/MDI-X) capability which simplifies network setups by automatically configuring the connection.
- StarTech.com 1 Port PCIe Network Card - Low Profile - RJ45 Port - Realtek RTL8111H Chipset - Ethernet Network Card - NIC Server Adapter Network Card (ST1000SPEX2L) - network adapter - PCIe - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- 6.5 cm x 6.79 cm
- 36 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Processor
- 1 x Realtek Semiconductor RTL8111E
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- 2-year warranty
- Network adapter
- Form Factor
- PCI Express x1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Status Indicators
- Port transmission speed, link/activity
- Full duplex capability, auto-uplink (auto MDI/MDI-X)
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45
- Included Accessories
- Full-height bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 6.5 cm
- 6.79 cm
- 36 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 10 - 90%
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.36 |
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £211.09 |
StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile | In Stock | £18.45 |
StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile | In Stock | £19.43 |
StarTech.com 1-Port Gigabit NIC - PCIe | In Stock | £28.06 |
