Make reliable Ethernet connections in applications requiring CMR-rated cable. This Cat5e 350MHz Solid UTP Cable is CMR rated for use in walls, conduit, ceilings, etc. and is packaged as a 1000ft bulk roll. The cable features a blue PVC jacket, which provides both flexibility and durability, while making it easier to color code network cable connections.
- StarTech.com 1000ft CAT5e Ethernet Cable - Blue - Bulk Roll - Solid UTP Cable - CMR Rated - Box of CAT5e Network Wire Cable (WIRC5ECMR) - bulk cable - 305 m - blue
- Bulk cable - CAT 5e
- Technology
- Solid
- Length
- 305 m
- Blue
- Package Type
- Bulk
- Limited lifetime warranty
- Designed For
- P/N: POEEXT1GAT, POEEXT2GAT, ST1000SPEX2, ST1000SPEX2L, ST1000SPEXI, ST121HDWP, ST5GPEXNB, STUTPWALLA, USB2001EXT2P, USB2001EXT2PNA, USB2001EXTV
- Network Cable Type
- Technology
- Jacket Material
- PVC
- Solid
- Length
- 305 m
- Blue
- Up to 350 MHz
- Package Type
- Bulk
- Designed For
StarTech.com RJ45 RJ11 Crimp Tool with Cable Stripper | In Stock | £23.80 |
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £205.95 |
StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable | In Stock | £203.87 |
