This PCI Express based 10/100 Ethernet Card provides a simple way to connect a PCIe enabled server or workstation to a 10/100 Ethernet network and offers a broad range of features and functions, including support for both Full and Half Duplex operation as well as Wake On LAN (WOL) Power Management.
The PEX100S Ethernet Card includes both standard and low profile brackets and is compatible with most mATX (Slimline) and ATX system form factors, and features Auto MDI/MDIX automatic configuration, which helps to simplify installation and configuration.
- StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card (PEX100S) - network adapter - PCIe - 10/100 Ethernet
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- 10/100 Ethernet
- 2.1 cm x 12 cm
- 45 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- Processor
- 1 x Realtek Semiconductor RTL8101E
- IEEE 802.3x
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019
- Limited lifetime warranty
- Network adapter
- Form Factor
- PCI Express x1
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 100 Mbps
- Status Indicators
- Port transmission speed
- Full duplex capability, auto-sensing per device, auto-negotiation, WOL, auto-uplink (auto MDI/MDI-X), half duplex mode
- IEEE 802.3x
Processor / Memory
- Processor
- 1 x 100Base-TX - RJ-45
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket, full-height bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Additional Requirements
- CD-ROM
- 2.1 cm
- 12 cm
- 45 g
- Limited warranty - lifetime
StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile | In Stock | £18.31 |
StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC | In Stock | £78.36 |
StarTech.com 4-Port Gigabit NIC - PCIe | In Stock | £151.83 |
StarTech.com 4-Port PCIe Gigabit NIC | In Stock | £118.88 |
