StarTech.com 1 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Quicklinx: 76T2WS00 Mfr#: PEX1S952
This PCI Express RS232 Serial adapter card adds an RS232 (DB9) Serial Port to a computer through an available PCI Express slot, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
Compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, and Linux Kernel 2.6.11 and up, the PEX1S952 PCI Express Serial Card also features an optional half-height/low profile bracket that allows the card to be installed in virtually any computer case, regardless of the case form factor.
StarTech.com 1 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter - PCIe - RS-232
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232
6.5 cm x 9 cm x 2 cm
48 g
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 2000, Apple MacOS X 10.4 or later, SuSE Linux Kernel 2.6.x, Microsoft Windows 2003, Microsoft Windows Vista / XP
Serial adapter
PCI Express x1
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232
Wired
RS-232
Data Transfer Rate
460 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
Low-profile bracket, full-height bracket
FCC, RoHS
Software Included
Drivers & Utilities
6.5 cm
9 cm
2 cm
48 g
76T2 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
