The PEX1S553LP PCI Express serial card turns a PCI Express slot into an RS232 (DB9) serial connection. The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 serial adapter card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista /Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and ships with a low profile/half-height bracket installed, but includes an optional full profile bracket that lets you add a serial port to virtually any computer (regardless of the case form factor). This product is a replacement for the PEX1S552LP card.
- StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART (PEX1S553LP) - serial adapter - PCIe - RS-232
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- Ports
- RS-232
- Data Link Protocol
- RS-232
- System Requirements
- Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4 - 10.7, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express
- WHQL, FCC
- OS Required
- Limited warranty - lifetime
- -20 °C
- 85 °C
- 5 - 85%
StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART | In Stock | £37.06 |
StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART | In Stock | £35.75 |
StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART | In Stock | £29.12 |
StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART | In Stock | £34.33 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
StarTech.com 2 Port PCI Express RS232 Serial Adapter Card | In Stock | £42.19 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £178.87 |
StarTech.com 1-Prt PCI Express Serial Card | In Stock | £41.71 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £48.46 |
