The ICUSB2321F 1-Port USB to Serial RS232 Adapter Cable with FTDI chipset and COM Retention converts an available USB 1.1 or 2.0 port into an RS232 serial DB9 port to connect, monitor and control your serial devices.
This compact adapter features COM retention, allowing the same COM port value to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. Unlike most of USB to serial adapters, this one uses the FTDI chipset which supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
Compatibility with a broad list of Operating Systems including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
- StarTech.com USB to Serial Adapter - 1 port - USB Powered - FTDI USB UART Chip - DB9 (9-pin) - USB to RS232 Adapter (ICUSB2321F) - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- 4.2 cm x 4.5 cm x 2.2 cm
- 200 g
- Data Link Protocol
- RS-232
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- USB powered
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated) - 1.8 cm
- FCC, RoHS
- Black
- OS Required
- 4.2 cm
- 4.5 cm
- 2.2 cm
- 200 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £20.31 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £31.08 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £19.03 |
StarTech.com 7 Port Black USB 2.0 Hub | In Stock | £22.43 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £15.11 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £4.30 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £3.98 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.09 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £21.60 |
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M | In Stock | £20.85 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £101.04 |
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.47 |
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.49 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.54 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £3.87 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.82 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.76 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £15.13 |
