Connect an RS232 (DB9) peripheral to your USB-C device. This USB-C to serial adapter lets you connect your USB-C devices to your legacy serial equipment. It converts a USB-C port on your laptop or computer into a RS232 DB9 serial port, giving you a cost-saving way to connect to serial devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The RS232 adapter cable is compatible with Windows, macOS and Linux operating systems, which makes it easy to integrate into mixed environments.
The USB-C to serial adapter is USB powered, so you don't need an additional external power supply. It's a compact solution that's easy to bring along with your laptop, when you're on the go.
Connect with ease
The RS232 adapter cable is compatible with Windows , macOS and Linux operating systems, which makes it easy to integrate into mixed environments. -
Ready for mobile or desktop applications
The USB-C to serial adapter is USB powered, so you don't need an additional external power supply. It's a compact solution that's easy to bring along with your laptop, when you're on the go. The ICUSB232C is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB C to Serial Adapter Cable 16" (40cm), USB Type C to RS232 (DB9) Converter Cable, USB-C Serial Cable for PLCs, Scanners, Receipt Printers, Male/Male, Windows/macOS/Linux - Up to 921.6 Kbps Baud - USB / serial cable - DB-9 to 24 pin USB-C - 40 cm
- Thumbscrews, Chipset Prolific PL2303RA
- Length
- 40 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 24 pin USB-C - male
- 2-year warranty
- Length
- 40 cm
- 8 g
- Connector
- WHQL
- 2-year warranty
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.85 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.44 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.28 |
StarTech.com UCB C to Serial Adapter | In Stock | £16.71 |
StarTech.com USB C to RS232 Cable | In Stock | £21.66 |
