Brand
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention
Quicklinx: 7NZ3WS00 Mfr#: ICUSB2321F
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB
More than 50 In Stock
£24.11 ex VAT
£28.93 inc VAT
The ICUSB2321F 1-Port USB to Serial RS232 Adapter Cable with FTDI chipset and COM Retention converts an available USB 1.1 or 2.0 port into an RS232 serial DB9 port to connect, monitor and control your serial devices.
This compact adapter features COM retention, allowing the same COM port value to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. Unlike most of USB to serial adapters, this one uses the FTDI chipset which supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
Compatibility with a broad list of Operating Systems including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
StarTech.com USB to Serial Adapter - 1 port - USB Powered - FTDI USB UART Chip - DB9 (9-pin) - USB to RS232 Adapter (ICUSB2321F) - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
4.2 cm x 4.5 cm x 2.2 cm
200 g
RS-232
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
USB powered
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 1.8 cm
FCC, RoHS
4.2 cm
4.5 cm
2.2 cm
200 g
55 °C
5 - 95%
7NZ3 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.54
7NZ3 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £33.25
7NZ3 StarTech.com 4 Port Black USB 2.0 Hub In Stock £20.37
7NZ3 StarTech.com 7 Port Black USB 2.0 Hub In Stock £23.41
7NZ3 StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £15.31
7NZ3 StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £4.95
7NZ3 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.17
7NZ3 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.24
7NZ3 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.11
7NZ3 StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £48.66
7NZ3 StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £22.11
7NZ3 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £108.11
7NZ3 StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips In Stock £60.21
7NZ3 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.05
7NZ3 StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £102.21
7NZ3 StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £174.29
7NZ3 StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.51
7NZ3 StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.76
7NZ3 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.33
7NZ3 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.43
7NZ3 StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £3.97
7NZ3 StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.99
7NZ3 StarTech.com USB to RS232 Serial Adapter In Stock £16.55
7NZ3 StarTech.com 16-Port USB-Serial Adapter Hub In Stock £456.58
7NZ3 StarTech.com 4 Port USB to Serial Hub In Stock £79.27
7NZ3 StarTech.com UCB C to Serial Adapter In Stock £18.31
7NZ3 StarTech.com 4-Port USB to Serial Adapter In Stock £244.59
7NZ3 StarTech.com 8-Port USB to Serial Adapter In Stock £388.76
Compatibility: Mac
Compatibility: PC
Interface: USB
