StarTech.com's USBthere offers simple USB extension, allowing you to place a USB device up to 165ft (50m) away from the computer - 10 times longer than normal USB cable length restrictions. The USB extender is comprised of both local and remote units, which can be connected together to extend the USB connection distance over standard Cat5e Ethernet cable.
Delivering cost-effective USB extension, the USBthere USB extender eliminates the expense of additional hubs, repeaters, power adapters or software, making it perfect for a broad range of applications including security and surveillance devices like USB video cameras etc.
The USBthere is designed to provide dependable, long-lasting USB device performance over long distances.
- StarTech.com 1 Port Cat5 USB Extender - USB extender - USB
- USB extender - 4 pin USB Type A / 4 pin USB Type A
- Form Factor
- External
- Data Transfer Rate
- 12 Mbps
- Data Link Protocol
- USB
- Max Transfer Distance
- 50 m
- System Requirements
- Microsoft Windows 98SE/2000/ME/XP
- 10 cm x 7 cm x 3 cm
- 0.1 kg
- 2-year warranty
- Designed For
- P/N: 35FCREADBK3
- USB extender
- Form Factor
- External
- Connectivity Technology
- Wired
- USB
- 12 Mbps
- 50 m
- 1 x USB - Type B , 1 x USB - Type A
- Cables Included
- 1 x USB cable - 2 m
- OS Required
- 10 cm
- 7 cm
- 3 cm
- 0.1 kg
- Limited warranty - 2 years
- 4 °C
- 40 °C
- Designed For
- P/N: 35FCREADBK3
