This innovative USB to Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to a laptop or desktop computer through USB - eliminating the expense of upgrading serial peripherals for compatibility.
A time-saving and convenient USB/Serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another.
A versatile connectivity solution that bridges legacy serial peripheral devices with newer USB-capable computers, the USB to Serial adapter is compatible with Win98/2000/XP/Vista and MAC OS 10.4+ operating systems.
- StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 1 Mbps
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Pocket PC 2000, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Mobile 6.0, Microsoft Windows Server 2012, Microsoft Windows 2000 / ME / XP, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 2.4.x - 4.19.x LTS versions only, Microsoft Windows CE 5.2
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 1 Mbps
- 1 x RS-232 - 9 pin D-Sub (DB-9) - male
- FCC
- Black
- OS Required
- Limited warranty - parts and labour - 2 years
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £14.62 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £21.00 |
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £57.42 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £10.04 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £15.15 |
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M | In Stock | £14.96 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £72.58 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £4.19 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F | In Stock | £4.30 |
StarTech.com 1 Port Industrial USB to RS232 Serial Adapter with 5KV Isolation & 15KV ESD Protection | In Stock | £53.65 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £10.86 |
