StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B
Quicklinx: 76VQWS00 Mfr#: UUSBHAUB1RA
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB1RA 1-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The right-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a 1ft USB A to Left Angle Micro B Cable (UUSBHAUB1LA), which provides the same convenience as this right-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 1 ft / 30cm Micro USB Cable - A to Right Angle Micro B - USB Type A (M) - 90 Degree Micro-USB Type B (M) - Black (UUSBHAUB1RA) - USB cable - USB to Micro-USB Type B - 30 cm
USB cable
90° connector, right-angled connector
Length
30 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
American Wire Gauge (AWG)
30
Length
30 cm
Connector
USB / USB 2.0, RoHS
76VQ StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £99.33
76VQ StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £44.71
76VQ StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £57.29
76VQ StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £51.70
76VQ StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £26.99
76VQ StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £15.45
76VQ StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £71.57
76VQ StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.58
76VQ StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £15.56
76VQ StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £131.83
76VQ StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £66.89
76VQ StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £60.86
76VQ StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.35
76VQ StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £11.54
76VQ StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £44.99
76VQ StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
76VQ StarTech.com 0.5m Angled Micro USB Cable In Stock £4.68
76VQ StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £34.39
