StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B
Quicklinx: 76VQWS00 Mfr#: UUSBHAUB1RA
Length: 30cm
More than 50 in stock
£3.76 ex VAT
£4.51 inc VAT
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB1RA 1-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The right-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a 1ft USB A to Left Angle Micro B Cable (UUSBHAUB1LA), which provides the same convenience as this right-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 1 ft / 30cm Micro USB Cable - A to Right Angle Micro B - USB Type A (M) - 90 Degree Micro-USB Type B (M) - Black (UUSBHAUB1RA) - USB cable - 30 cm
USB cable
90° connector, right-angled connector
Length
30 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
American Wire Gauge (AWG)
30
Length
30 cm
Connector
USB / USB 2.0, RoHS
76VQ StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.92
76VQ StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B In Stock £1.87
76VQ StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.76
76VQ StarTech.com 6 ft Micro USB Cable A to Left Angle Micro B In Stock £4.78
76VQ StarTech.com 6 ft Micro USB Cable A to Right Angle Micro B In Stock £4.78
76VQ StarTech.com 0.5m Angled Micro USB Cable In Stock £3.87
Length: 30cm
Price Range Ex VAT: 0 - 50
