Connect two DVI-D displays simultaneously to a single DVI-D video source. The DVISPL1DD 1ft DVI-D Splitter Cable lets you connect two DVI-D displays, or projectors to a single DVI-D digital video output port on your computer.
The DVISPL1DD is a reliable and cost-effective solution for dual DVI monitor configurations.
- StarTech.com 1 ft DVI-D to 2x DVI-D Digital Video Splitter Cable - M/F (DVISPL1DD) - video splitter - DVI - 30.5 cm
- Cable
- Video splitter - DVI
- Technology
- Shielded
- TMDS Links
- Dual link
- Length
- 30.5 cm
- Black
- Connector
- 2 x DVI-D - female
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Designed For
- P/N: DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M
- Cable Type
- Video splitter
- Interface Supported
- DVI
- Technology
- Shielded
- TMDS Links
- Dual link
- Length
- 30.5 cm
- Plated Connector
- Gold
- Black
- Connector
- 2 x 24+1 pin digital DVI - female
- 24+1 pin digital DVI - male
- UL, RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.80 |
StarTech.com 2 Port DVI Video Splitter with Audio | In Stock | £89.33 |
StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F | In Stock | £13.14 |
StarTech.com 1 ft DVI-D to 2x DVI-D Digital Video Splitter Cable - M/F | In Stock | £12.18 |
StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £66.16 |
StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £65.01 |
