StarTech.com 1.2m 3.9ft 10G SFP+ DAC Cable
Quicklinx: D9TCWS00 Mfr#: JD096CST
Length: 1.2m
Colour: Black
Select:
Hurry, only 2 left in stock!
£27.86 ex VAT
£33.43 inc VAT
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com 1.2m 10G SFP+ to SFP+ Direct Attach Cable for HPE JD096C 10GbE SFP+ Copper DAC 10 Gbps Low Power Passive Twinax - 10GBase direct attach cable - 1.2 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
1.2 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
HP JD096C
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
1.2 m
75 g
Connector
SFP+ - latched
SFP+ - latched
HP JD096C
FCC, RoHS, MSA
70 °C
D9TC StarTech.com 1m 3.3ft 10G SFP+ DAC Cable In Stock £35.99
D9TC StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £44.36
D9TC StarTech.com 7m 23ft 10G SFP+ DAC Cable In Stock £56.29
D9TC StarTech.com 0.65m 2.1ft 10G SFP+ DAC Cable In Stock £27.70
D9TC StarTech.com 1.2m 3.9ft 10G SFP+ DAC Cable In Stock £27.86
D9TC StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £36.11
D9TC StarTech.com 5m 16.4ft 10G SFP+ DAC Cable In Stock £40.83
Length: 1.2m
Colour: Black
Price Range Ex VAT: 0 - 50
