Brand
StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser
Quicklinx: 8MRBWS00 Mfr#: USBDUP12
34 in stock
£116.78 ex VAT
£140.13 inc VAT
Easily duplicate one USB 2.0 Flash Drive to two Flash Drives simultaneously or Erase USB Flash Drives, without connecting to a computer. The USBDUP12 Standalone Flash Drive Duplicator/Eraser offers a quick and easy solution for cloning a USB flash drive to one or two target USB flash drives or erasing up to two thumb drives simultaneously without having to connect the drives to a computer system.
Featuring high performance duplications at up to 1.5GB per minute, the flash drive copier has a lightweight design and user friendly interface that includes an integrated LCD display. The duplicator can copy the entire source drive volume, or for quicker backups just the data on the drive.
In addition, the target USB ports of the duplicator also support connecting to external USB storage devices. The standalone USB duplicator supports copying/cloning to SD/ SDHC/ Micro SD/ MMC/ Mini SD/ CF media through a USB multimedia card reader (sold separately), and to Hard Drives or Solid State Drives through a Hard Drive docking station or USB enclosure.
The Drive Duplicator also functions as a Flash Drive Eraser capable of erasing up to two USB drives simultaneously with several erase modes available including Quick erase and Full erase, as well as Secure erase, which follows the USA Department of Defense (DoD) secure erase standard, passing over the flash drive 3 times to ensure that the data has been completely wiped.
StarTech.com 1:2 Standalone USB Duplicator and Eraser - Memory Stick Cloner - USB 2.0 Flash Drive Copier / Thumb Eraser (USBDUP12) - USB drive duplicator
2 (max)
North America, United Kingdom, Europe
Built-in Devices
Status LCD
Hard Drive
No HDD
AC 120/230 V
13 cm x 12 cm x 2.5 cm
190 g
P/N: SVA5H2NEUA
Enclosure Colour
Chassis
Built-in Devices
Status LCD
Supported Devices / Modules Qty
2
Hard Drive
No HDD
3 x USB 2.0 - 4 pin USB Type A
FCC, RoHS
External power adapter
AC 120/230 V
13 cm
12 cm
2.5 cm
190 g
5 °C
45 °C
5 - 95%
P/N: SVA5H2NEUA
8MRB StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £701.85
Stock Status: In stock
