Duplicate one 2.5/3.5" hard drive to another without connecting to a computer, or backup multiple drive images to a library drive to restore PC/Server images easily. The SATDUP11IMG standalone SATA hard drive duplicator, lets you create an exact duplicate of a SATA hard drive (HDD) / solid state drive (SSD), or create a single backup library drive containing multiple images you can copy to additional drives at any time.
Reduce clutter with the SATDUP11IMG eliminating the number of drives required when creating backups of multiple unique drive images. Using a single backup library drive, you can store several unique drive images on a single SSD / HDD, ensuring fast duplication at 6 GBpm and minimal clutter. This is an ideal solution if you frequently re-image different computer systems, because it means you'll only have to carry a single backup library drive to restore multiple drive images onto different systems.
The versatile duplicator also offers standard one-to-one drive duplication in three different modes: file & system copy, all partitions copy and whole copy. This is ideal for one-time drive duplication, eliminating the hassle of creating a drive image for a one-time project.
With an easy-to-read LCD display and intuitive four-button menu operation, the SATDUP11IMG ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: drive to drive duplication, drive to Image library backup and restore, and many more. It also provides numerous advanced setup options for experienced users.
The SATDUP11IMG is TAA compliant.
Fast, Simple Drive Duplication
Reduce clutter with the SATDUP11IMG eliminating the number of drives required when creating backups of multiple unique drive images. Using a single backup library drive, you can store several unique drive images on a single SSD / HDD, ensuring fast duplication at 6 GBpm and minimal clutter.This is an ideal solution if you frequently re-image different computer systems, because it means you'll only have to carry a single backup library drive to restore multiple drive images onto different systems. -
Hassle-free Performance
The versatile duplicator also offers standard one-to-one drive duplication in three different modes: file & system copy, all partitions copy and whole copy. This is ideal for one-time drive duplication, eliminating the hassle of creating a drive image for a one-time project. -
Intuitive Operation
With an easy-to-read LCD display and intuitive four-button menu operation, the SATDUP11IMG ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: drive to drive duplication, drive to Image library backup and restore, and many more. It also provides numerous advanced setup options for experienced users. For added compatibility with different drive types in duplication, the SATDUP11IMG supports the use of various drive adapters. The below list of StarTech.com adapters have been specifically tested, to ensure compatibility with this drive duplicator: 2.5/3.5in IDE drives - SAT2IDEADP mSATA drives - SAT2MSAT25 M.2 (NGFF) drives - SAT32M225 The SATDUP11IMG is TAA compliant and backed by a 2-year StarTech.com warranty and lifetime technical support.
- StarTech.com 11 Standalone Hard Drive Duplicator with Disk Image Library Manager For Backup & Restore, Store Several Images on one 2.53.5 SATA Drive, HDDSSD Cloner, No PC Required - TAA Compliant - hard drive duplicator
- Hard drive duplicator
- Black
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- Supported Drives
- SATA-600
- Localisation
- North America, United Kingdom, Europe
- Built-in Devices
- Status LCD
- Storage Controller
- SATA (SATA 6Gb/s)
- Power
- AC 120/230 V - 50/60 Hz
- 13 cm x 8 cm x 3 cm
- 350 g
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 2
- Supported Drives
- SATA-600
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Max Storage Devices Qty
- 2
- Expansion Bays
- 2 (total) / 2 (free) x external - 2.5" / 3.5" shared
- 2 x SATA 6Gb/s - 22 pin Serial ATA
- Cables Included
- 2 x Serial ATA cable
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- 13 cm
- 8 cm
- 3 cm
- 350 g
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 20 - 80%
- Designed For
- P/N: SVA12M5NA
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.33 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.65 |
StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock | In Stock | £424.61 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.36 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £15.89 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £29.96 |
StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser | In Stock | £114.42 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.57 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library | In Stock | £268.90 |
StarTech.com SATA/SAS Duplicator & Eraser | In Stock | £998.03 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com USB and SATA Cloner / Eraser | In Stock | £472.21 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £751.08 |
