StarTech.com 0.5m USB to USB-C Cable 10Gbps
Quicklinx: D72PWS00 Mfr#: USB31AC50CM
Length: 50cm
£8.64 ex VAT
£10.36 inc VAT
Connect a USB Type-C device to your laptop or desktop computer with reduced clutter. This USB to USB-C cable lets you connect your USB 3.1, USB Type-C devices such as a portable drive, or mobile device to the USB Type-A port on your computer, or charger.
This 0.5-meter cable is great for close-range connections to charge and sync your mobile devices with your laptop. You can move large files or transfer movies can be done in seconds, at twice the speed of USB 3.0 and 20x faster than USB 2.0.
You can also use the cable to charge your devices from a USB-A wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room. It lets you connect a USB 3.1 peripheral device, such as your external hard drive to your laptop, without excess cable getting in your way.
With a bandwidth of 10Gbps, this USB 3.1 Gen 2 cable lets you sync your USB Type-C devices in no time at all. You can spend less time transferring and backing up your data and more time focusing on your projects and presentations.
StarTech.com USB to USB C Cable - 1.6 ft / 0.5m - M/M - USB 3.1 (10Gbps) - USB-C to USB 3.1 - USB Type C to Type A Cable (USB31AC50CM) - USB-C cable - 50 cm
USB-C cable
10 Gbps data rate
Length
50 cm
Connector
9 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2
P/N: 4SD4FCRU31C, HBS304A24A, M2E1BMU31C, M2E1BRU31C, PEXUSB311AC3, S251BRU31C3, SDOCK4U313
USB-C cable
10 Gbps data rate
Length
50 cm
Connector
24 pin USB-C - male
USB 3.1 Gen 2
D72P StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.49
Length: 50cm
Price Range Ex VAT: 0 - 50
