Charge and Sync your Micro USB-equipped Smartphone or Tablet with reduced clutter. The USBAUB50CMBK Micro USB Cable is perfect for close-range connections, and provides a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
The short 0.5m cable length makes this an ideal charge cable for in-car use or to reduce clutter when syncing to your laptop - perfect for people on the move, for providing simple, tidy connections.
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
Reliable connection
This USB cable provides a secure and stable connection for charging and syncing devices, ensuring consistent performance during use. -
Enhanced durability
Built with double shielding, this cable is designed to withstand daily wear and tear, prolonging its lifespan and maintaining performance. -
Excellent conductivity
Featuring nickel-plated connectors, this cable minimizes resistance and enhances conductivity for faster data transfers and charging speeds.
- StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable M/M - USB cable - Micro-USB Type B to USB - 50 cm
- USB cable
- Technology
- Double shielded
- Length
- 50 cm
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £4.30 |
StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £5.40 |
StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable - M/M | In Stock | £4.74 |
StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £4.59 |
StarTech.com 3m USB / Slim Micro USB Cable | In Stock | £5.70 |
