Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
- StarTech.com Cisco QSFP-H40G-CU0-5M Compatible 0.5m 40G QSFP+ to QSFP+ DAC Twinax, 40G QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower C9200, 40GE Cable - Lifetime Warranty (QSFPH40GCU05) - 40GBase direct attach cable - 50 cm - black
- 40GBase direct attach cable - SFF-8436
- Technology
- Twinaxial
- Passive cable
- Length
- 50 cm
- Connector
- QSFP+ - latched
- Connector (Second End)
- QSFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco QSFP-H40G-CU0-5M
- 2-year warranty
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 30
- Impedance
- 100 Ohm
- Passive cable
- Length
- 50 cm
- 36 g
- Black
- Connector
- QSFP+ - latched
- QSFP+ - latched
- FCC, RoHS, MSA
- 2-year warranty
- 0 °C
- 70 °C
StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable | In Stock | £162.96 |
StarTech.com 3m 9.8ft 40G QSFP+ DAC Cable | In Stock | £155.11 |
StarTech.com 5m 16.4ft 40G QSFP+ DAC Cable | In Stock | £33.24 |
