Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
 - StarTech.com MSA Uncoded Compatible 0.5m 40G QSFP+ to QSFP+ Direct Attach Breakout Cable Twinax, 40 GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, 40GE, 40GE Cable - Lifetime Warranty (QSFP40GPC05M) - 40GBase direct attach cable - 50 cm - black
 - 40GBase direct attach cable - SFF-8436
- Technology
 - Twinaxial
 - Passive cable
- Length
 - 50 cm
- Connector
 - QSFP+ - latched
- Connector (Second End)
 - QSFP+ - latched
 - Black
 - 2-year warranty
- Network Cable Type
- Technology
 - Twinaxial
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 30
- Impedance
 - 100 Ohm
 - Passive cable
- Length
 - 50 cm
 - 36 g
 - Black
- Connector
 - QSFP+ - latched
 - QSFP+ - latched
 - FCC, RoHS, MSA
 - 2-year warranty
 - 0 °C
 - 70 °C
