StarTech.com 0.5m 1.6ft 40G QSFP+ DAC Cable
Quicklinx: D9TQWS00 Mfr#: QSFP40GPC05M
Length: 50cm
Colour: Black
Select:
  • 0.5m
£20.89 ex VAT
£25.06 inc VAT
Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com MSA Uncoded Compatible 0.5m 40G QSFP+ to QSFP+ Direct Attach Breakout Cable Twinax, 40 GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, 40GE, 40GE Cable - Lifetime Warranty (QSFP40GPC05M) - 40GBase direct attach cable - 50 cm - black
40GBase direct attach cable - SFF-8436
Twinaxial
Passive cable
Length
50 cm
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
50 cm
36 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 50cm
Colour: Black
