StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable
Quicklinx: D9VQWS00 Mfr#: SFPH10GBC05M
Length: 50cm
Colour: Black
Select:
10 in stock
£28.00 ex VAT
£33.60 inc VAT
Connect your Cisco 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com Cisco SFP-H10GB-CU1M Comp SFP+ Twinax Cable - 0.5 m (1.6 ft.) - 10GBase direct attach cable - 50 cm - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
50 cm
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Cisco SFP-H10GB-CU0-5M
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
50 cm
Connector
SFP+ - latched
SFP+ - latched
FCC, RoHS, MSA
70 °C
D9VQ StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable In Stock £28.00
D9VQ StarTech.com 1.5m 4.9ft 10G SFP+ DAC Cable In Stock £39.48
D9VQ StarTech.com 2.5m 8.2ft 10G SFP+ DAC Cable In Stock £40.94
D9VQ StarTech.com 6m 20ft 10G SFP+ DAC Cable In Stock £83.94
Length: 50cm
Colour: Black
Price Range Ex VAT: 0 - 50
