Connect your Cisco 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting applications such as point-to-point in-rack and across-rack network switch or server connections.
- StarTech.com Cisco SFP-H10GB-CU6M Compatible 6m 10G SFP+ to SFP+ DAC Twinax, 10GbE SFP+ Copper DAC 10Gbps/10GE Low Power Passive SFP+ Transceiver Module DAC Cable, Cisco Firepower ASR9000 - Lifetime Warranty (SFPH10GBCU6M) - 10GBase direct attach cable - 6 m - black
- 10GBase direct attach cable - SFF-8431/SFF-8432
- Technology
- Twinaxial
- Passive cable
- Length
- 6 m
- Connector
- SFP+ - latched
- Connector (Second End)
- SFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-H10GB-CU6M
- Limited lifetime warranty
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 30
- Impedance
- 100 Ohm
- Passive cable
- Length
- 6 m
- 380 g
- Black
- Connector
- SFP+ - latched
- SFP+ - latched
- FCC, RoHS, MSA
- 0 °C
- 70 °C
StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable | In Stock | £25.03 |
StarTech.com 1.5m 4.9ft 10G SFP+ DAC Cable | In Stock | £33.33 |
