Sony VPL-SW631 UXGA 1600 x 1200 RGB HDMI 3LCD Projector
Quicklinx: C057WS00 Mfr#: VPL-SW631#S3859632
Bright, high contrast widescreen projector for mid-size classrooms and meeting rooms: with easy installation and low ownership costs. The VPL-SW631 Ultra Short Throw projector is ideal for classroom or corporate use, with simple, flexible installation, low ownership costs and easy connection to other devices.
Present big, bright images over 2m across with the projector as little as 47cm from the screen or whiteboard, with less distracting glare and shadows.
Advanced 3LCD BrightEra panel technology by Sony ensures high contrast, widescreen WXGA images with excellent color stability. The projector's powerful 3,300 lumens color light output ensures that presentations are always seen clearly, even in brightly-lit environments.
Seamless integration with school or office networks can be enhanced with an optional Wi-Fi module, letting students wirelessly share homework, images and graphics from PCs, smartphones and tablets.
There's a wide range of smart energy-saving features built in. An extra-long lamp replacement time of up to 10,000 hours minimizes costs and reduces downtime in busy classrooms and offices.
  • Bright, clear images with maximum 3,300 lumens color light output
    The projector's high light output ensures that presentations are seen clearly in any classroom or meeting room. There's a choice of three brightness modes to suit any environment, from bright daylight to darkened rooms.
  • Ultra short throw distance
    Present images up to 80" across (2.03m diagonal) with the projector just 47cm from the screen or whiteboard. Distracting glare and shadows are greatly reduced, as well as saving space in a classroom or meeting room.
  • WXGA resolution for detail-packed presentations
    WXGA (1280 x 800) resolution gives lots of crisp, fine detail: perfect for making presentations direct from a laptop or PC.
  • 3LCD BrightEra technology
    The projector's efficient 3LCD panel system is enhanced by advanced BrightEra technology by Sony. You'll see the difference with impressively bright, consistent, high resolution images and increased panel reliability.
  • Gamma adjustment
    A new gamma curve adjustment offers three settings for accurate tonal reproduction with rich, punchy colors and clear, easy-to-read text.
  • Up to 10,000 hours (in Low mode) long-lasting lamp for reduced maintenance and down time
    Present for longer without interruption, with reduced maintenance that contributes directly to lower lifetime ownership costs. Filter cleaning cycles are synchronized with lamp replacement, cutting scheduled maintenance visits even further.
  • Energy-saving features
    Advanced lamp technology enables a range of energy-saving features. Auto Light Dimming mode saves energy when the projector is left on without being used. During projection, Auto Picture Mode automatically adjusts light output to suit the scene being projected. Picture Mute dims the projected image when it's not needed to minimize energy consumption.
  • Wired or wireless network presentation
    Upgraded Network Presentation software (included) makes it easier than ever to deliver presentations from a networked PC or Mac with simple one-click connection. Up to four users can project PC/Mac images simultaneously, and up to eight users can connect to one projector.
  • Remote control from iOS mobile devices
    Download free Projector Remote app for iOS and easily control projector features from anywhere in the room with your iPhone or iPad.
  • USB Media viewer
    Insert a USB drive and display photos, images or graphics with no PC needed.
  • USB display for easy one-cable PC connection
    Present pictures and audio from a connected PC or Mac with just one USB cable - you don't even need to install a software driver.
  • Input label function
    It's easier to keep track of various sources with an input label function that lets you see the name of connected PCs, cameras, BD/DVD players and other devices on screen.
  • Clear, rich audio from built-in speaker
    There's no need to add an extra audio system: enjoy rich, room-filling sound from the powerful 16W speaker.
  • Quick and easy to install
    Adjustable optical zoom and lens shift simplify speedy, fuss-free installation in any classroom. Generous connections simplify hook-ups with PCs, DVD players, microphones and other AV devices.
  • Easy wall mounting
    Installation's even easier with a new wall mounting bracket design that gives extra flexibility in rooms with low ceilings.
Sony VPL-SW631 - 3LCD projector - ultra short-throw - LAN
3LCD projector
Brightness
3300 lumens
Brightness (Colour)
3300 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Ultra short-throw lens
Lens Shift Direction
Horizontal, vertical
Bulb type
Ultra high-pressure mercury 225 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i
Speakers
Speaker(s) - integrated
320 Watt
37.2 cm x 38.2 cm x 13.8 cm
6 kg
3LCD projector
Ethernet
Projector
Brightness
3300 lumens
Brightness (Colour)
3300 lumens
Contrast Ratio
3000:1
Image Size
178 cm - 292 cm
Throw Ratio
0.27:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
OSD Languages
Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, Ultra Short Throw Technology, Auto Dimming Mode, USB Viewer, USB Display, Eco Mode, smartphone remote control
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.03x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-5/ +5
Lens Shift Type
Manual
Vertical Lens Shift
3.1% / 3.1%
Horizontal Lens Shift
2.3% / 2.3%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin D-Sub (DB-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x composite video input - RCA
Remote control
Power Source
AC
320 Watt
Power Consumption Stand by
0.5 Watt
37.2 cm
38.2 cm
13.8 cm
6 kg
20 - 80% (non-condensing)
Sound Emission
28 dB
