360° sound experience
Enjoy a 360° superior circle sound experience for your entire iTunes collection. -
Stream music without wires
Effortlessly stream music to the dock speaker from your iPod/iPhone. -
Bluetooth
Effortlessly stream music to the speakers from your Bluetooth stereo compatible device such as a smartphone. -
Stylish design
Fits perfectly in your living room and smaller spaces, like a kitchen, den, bedroom or other second room. -
USB charging
USB port charges your SmartPhone, iPod/iPhone/iPad and Walkman while you listen back.
- Sony SRS-BTV25 - speaker - wireless
- Product Type
- Speaker
- Enclosure Design
- Bass reflex
- Speaker Type
- 2-way - active
- Continuous Power
- 13 Watt
- Nominal Impedance
- 4.7 kOhm
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 1 x speaker 13 Watt 6 Ohm
- Black
- Power
- AC 120/230 V
- Power Options
- USB charging
- 14.5 cm x 14.5 cm x 14.5 cm
- 0.5 kg
- Product Type
- Speaker
- Enclosure Colour
- Black
- Enclosure Design
- Bass reflex
Speaker System
- Speaker Type
- 2-way - active
- Continuous Power
- 13 Watt
- Nominal Impedance
- 4.7 kOhm
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Volume, bass boost
- Speakers Included
- 1 x speaker - 2-way - 13 Watt - 6 Ohm - wireless
- Driver Details
- Speaker: woofer driver - 2.2" , Speaker: tweeter driver - 0.79"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
- Included Accessories
- Power adapter
- Power Device
- Power adapter - external
- Power Source
- AC power adapter
- Voltage Required
- AC 120/230 V
- 12 Watt
- Options
- USB charging
- 14.5 cm
- 14.5 cm
- 14.5 cm
- 0.5 kg
