Designed for education, the VPL-SW536 WXGA projector provides the perfect teaching tool for glare-less projection in changing light conditions. The VPL-SW536 WXGA projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets. Excellent contrast, consistent color stability, high picture quality and longer durability improve visibility enhancing teaching quality.
- Sony VPL-SW536C - 3LCD projector - LAN
- 3LCD projector - High Definition 720p
- White
- Built-in Devices
- Speaker
- Bundled Services
- 3 years PrimeSupport
- Brightness
- 3100 lumens
- Contrast Ratio
- 2500:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- Ultra high-pressure mercury 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) / up to 6000 hour(s) (economic mode)
- Video Input
- RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
- Video Modes
- 480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 282 Watt
- 38.44 cm x 42.34 cm x 12.25 cm
- 6.9 kg
- 3LCD projector - HD 720p
- Built-in Devices
- Speaker
- Bundled Services
- Enclosure Colour
- White
Projector
- Brightness
- 3100 lumens
- Brightness (Reduced)
- 2000 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 177.8 cm - 330.2 cm
- Throw Ratio
- 0.27 - 0.29:1
- Digital Zoom Factor
- 4x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
- Picture Muting, Auto Input Search, 3LCD Technology, BrightEra, Wireless Ready, Automatic Brightness Adjustment, Auto Dimming Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.05x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x microphone - mini-phone stereo 3.5 mm
- Included Accessories
- Remote control
- UL, cUL, NOM, SABS, SASO, CCC, PSB, GOST-R, KUCAS
- Nominal Voltage
- 282 Watt
- 38.44 cm
- 42.34 cm
- 12.25 cm
- 6.9 kg
- Limited warranty - 3 years , Limited warranty - lamp - 3 years / 3000 hours
- 0 °C
- 40 °C
- 35 - 85% (non-condensing)
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 28 dB
