Sony LCD projector 5000 lumens WUXGA (1920 x 1200)
Quicklinx: CSZ7WS00 Mfr#: VPL-CH370
The VPL-CH370 delivers an outstanding brightness of ultra high-quality images with WUXGA resolution. Sony 3LCD BrightEra panel technology provides higher picture quality, substantially brighter images, higher efficiency, consistent color stability and longer durability. It also delivers installation flexibility, environment-friendly features, and a low total cost of ownership, in a stylish design that blends into any decor. The lens shift/zoom capability and the image correction features easily allow users to fit any image onto the screen, even from an offset projection angle.
Additionally, the projector is economically designed for optimum energy efficiency, thanks to its energy saving features and has all the features and functionality that you would expect from Sony, particularly in terms of installation, projection, usability and maintenance.
  • High resolution WUXGA image
    The VPL-CH370 delivers an amazing resolution of WUXGA. Extremely clear and detailed high-quality images are projected, even on a large screen. The VPL-CH370 is the ultimate tool for projecting images in a range of applications requiring exceptional detail.
  • High image quality 3LCD BrightEra natural and vivid color images with high brightness
    Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, which ensures colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms.
  • Blend-in design
    The VPL-CH370 has a low-profile chassis, so it appears to blend into the ceiling or wall on which it is mounted.
  • Advanced energy-saving features
    Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto Light Dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto Picture Mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption.
Sony VPL-CH370 - 3LCD projector
3LCD projector - 1080p
Built-in Devices
Speaker, Fast Ethernet network adapter
Brightness
5000 lumens
Contrast Ratio
2500:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
Ultra high-pressure mercury 280 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
Video Input
(SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
388 Watt
40.6 cm x 33.05 cm x 11.3 cm
5.7 kg
Pricing Type
Refurbished
Built-in Devices
Ethernet
Projector
Brightness
5000 lumens
Brightness (Reduced)
3100 lumens
Contrast Ratio
2500:1
Image Size
102 cm - 762 cm
Throw Ratio
1.5 - 2.2:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Display Format
6,912,000 pixels (1920 x 1200) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Multilingual
High-bandwidth Digital Content Protection System (HDCP), BrightEra
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.45x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-20 / +20
Lens Shift Type
Manual
Vertical Lens Shift
5% / 5%
Horizontal Lens Shift
4% / 4%
Video Input
TV System
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
12 Watt
Speakers
1 x mixed channel
1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) (male) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Remote control
Pricing Type
Refurbished
Power Source
AC
388 Watt
Power Consumption Stand by
0.5 Watt
40.6 cm
33.05 cm
11.3 cm
5.7 kg
20 - 80% (non-condensing)
29 dB
