Sony Lamp for VPL-HW10/VPL-VW80
Quicklinx: 64P3WS00 Mfr#: LMP-H201
LMP-H201 is a replacement lamp for video projector, the VPL-HW10 and VPL-VW70. It is a 1.1mm short arc Ultra High Pressure lamp with compact reflector. The lamp wattage is selectable between 200W and 152W. By making it selectable lower wattage;152W, lamp life will be extended while reducing fan noise.
  • Enhanced Brightness
    Equipped with a 200 W UHP lamp, this projector accessory significantly boosts brightness, making presentations more vivid and engaging.
  • Seamless Compatibility
    Designed specifically for PC use, this projector lamp ensures seamless integration with your existing setup, enhancing your viewing experience without the need for complex adjustments.
Sony LMP-H201 - projector lamp
Projector lamp - UHP - 200 Watt
BRAVIA VPL-HW10, VPL-HW15, VPL-VW70, VPL-VW80; VPL-HW15, HW20, VW70, VW80, VW85, VW90ES
Projector lamp
Lamp
UHP
200 Watt
Sony BRAVIA VPL-HW10, VPL-HW15, VPL-VW70, VPL-VW80 , Sony VPL-HW15, HW20, VW70, VW80, VW85, VW90ES
