Enhanced brightness
The ultra high-pressure mercury lamp with a 210 W capacity ensures your presentations are vivid and bright, even in well-lit rooms. Its high wattage allows for clearer, more impactful visuals, making it an ideal choice for professional settings where clarity is paramount. -
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup. Its compatibility ensures a hassle-free installation process, allowing you to upgrade your projector's performance without the need for complex adjustments or technical support.
- Sony LMP-D213 - projector lamp
- Product Type
- Projector lamp - ultra high-pressure mercury - 210 Watt
- Designed For
- VPL-DW120, DW125, DX120, DX125, DX140, DX145
- Product Type
- Projector lamp
Lamp
- Ultra high-pressure mercury
- Capacity
- 210 Watt
- Designed For
- Sony VPL-DW120, DW125, DX120, DX125, DX140, DX145
