Sony ICD-AX412F Digital Dictation Device
Quicklinx: 7NGHWS00 Mfr#: ICDAX412FS.CE7
  • microSD
  • MP3
This digital voice recorder is super easy to use, and records in high quality stereo sound. The built-in S-Microphone System and a wider recording range provide high sensitivity and less noise. Built-in FM tuner easily catches up on your favorite shows in between recordings. Red and green illuminated LED buttons display rec/play status, at a glance. The recorder easily connects to your PC with USB direct link, simply plug in and share content.
  • S-Mic
    High sensitivity and less noise with built-in S-Microphone System, and a wider recording range.
  • Flashing LEDs
    Red and green illuminated buttons display rec/play status, at a glance.
  • Built-in stand
    Elevates device off the desk for vibration free recording, and a wider stereo range.
  • USB for PC
    Easy PC connection with USB direct link - simply plug in and share content.
  • MP3 recording/playback
    Capture high quality crystal clear audio, and listen back through the front speaker.
  • FM radio
  • Scene selection
    Choose the type of recording you want to capture for optimized settings.
  • Intelligent noise cut
    Enhances human speech for a much clearer audible range, and reduces distracting background noise.
  • Track mark
    Add multiple bookmarks to each recording, and jump to next/previous during playback.
  • LCD display
    Easily manage your recordings with the Dot-Matrix LCD display and backlight.
Sony ICD-AX412F - voice recorder
Voice recorder flash based
Playback Digital Standards
MP3
Digital Recording Time
536 hours - LP (Long Play)
Radio
FM
Supported Flash Memory Cards
microSD, Memory Stick Micro M2
Internal Memory
2 GB
Speakers
1 x speaker - built-in - 300 mW
Headphones
Headphones - binaural - stereo
Microphone
Microphone - built-in - stereo
USB
2 x AAA type
Voice recorder
Digital Player Type
Flash based
Interface Supported
USB
Audio Formats
MP3
Audio System
Internal Memory
2 GB
File System Supported
2 GB
Functions
Digital player, digital voice recorder, radio
Voice operated recording, FM radio recording capability, USB bus-powered, low-cut filter, Digital Pitch Control, Intelligent Noise Cut
Display
Display Menu Language
English, German, French, Italian, Russian, Spanish
Speaker System
Speakers
Digital Player (Recorder)
Recording Time
Supported Bit Rate
192Kbps
Radio
Radio Tuner
Digital radio tuner - FM
Headphones
Headphones Type
Wired
Sound Output Mode
Stereo
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB , Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
Carrying pouch, audio cable, USB cable
1 x USB cable , 1 x audio cable
Software
Drivers & Utilities, Sound Organizer
2 x AAA type
