Sony 2700 Lumens XGA Desktop Projector
Quicklinx: CFVKWS00 Mfr#: VPL-DX220
The VPL-DX220 XGA projector is a cost-effective yet fully-featured choice for clear, bright presentations in offices, meeting rooms and school classrooms. Light, compact and energy efficient, it's easy to set up and connect with other devices. Bright light output with 3LCD technology ensures crisply detailed XGA resolution images, that are always seen clearly, even in brightly-lit rooms. Auto Start gets you presenting faster, while Quick Power Off saves time, when you're in a hurry to the next meeting. Other presenter-friendly features include grid line templates for neater written notes on a whiteboard, plus a timer, that reminds speakers not to outstay their welcome. Running costs are kept down by clever energy-saving features. Simplified maintenance and a long lamp replacement time help reduce downtime in busy classrooms and offices.
  • Light, compact and stylish
    Weighing less, the space-saving VPL-DX220 is easy to carry between meeting rooms or classrooms.
  • Bright, clear images with maximum color light output
    The projector's generous light output ensures, that presentations are seen clearly in classrooms and meeting rooms.
  • XGA resolution for crisp presentations
    XGA (1024 x 768) resolution gives lots of fine detail: useful for making presentations direct from a laptop or tablet.
  • 3LCD BrightEra technology
    The efficient 3LCD panel system is enhanced by advanced BrightEra technology by Sony. You'll see the difference with impressively consistent, high resolution images and excellent reliability.
  • Picture modes
    There's a choice of seven picture modes to fine-tune your image with any kind of content - including Vivid mode for brighter-looking pictures, that really stand out with more powerful, high-impact color.
  • Gamma adjustment
    Gamma curve adjustment offers three settings for accurate tonal reproduction with rich, punchy colors and clear, easy-to-read text.
  • Get presenting faster
    Auto Start detects signals from a connected HDMI or VGA source, turning on the projector lamp, so you're all ready to start presenting.
  • Switch off and go
    Quick Power Off shortens cool-down time after switch-off at the end of a presentation - saving time when you're in a hurry to the next meeting.
  • Presentation timer
    Speakers can keep an eye on their allocated presentation time, with a count-up or count-down timer in a corner of the screen.
  • Make neater notes
    Pick from a choice of super-imposed grid and ruled line templates to make neat handwriting and drawing easier, when you're projecting onto a white board.
  • Long-lasting lamp
    The energy-efficient lamp driver contributes to an impressive lamp replacement interval.
  • Reduced ownership costs
    There's a range of energy-saving features to drive down total ownership costs. Auto Mode adjusts lamp brightness depending on picture content. Lamp Dimming progressively reduces brightness, if no input's detected, or after a preset time. Touching the Blank button on the projector remote instantly mutes the picture, when it's not needed.
  • Audio out
    Audio terminals allow direct connection of active speakers (not included) to suit the needs of any room.
  • Easy access, simple maintenance
    Lamp access on the top panel of the projector simplifies lamp replacement, whether the projector's ceiling- or table-mounted. There's also a sliding air filter and detachable dust cover, for easy maintenance without having to remove the projector from its ceiling mount.
Sony VPL-DX220 - 3LCD projector - portable
3LCD projector
Built-in Devices
Speaker
Brightness (White)
2700 lumens
Brightness (Colour)
2700 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 215 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
32.51 cm x 23.05 cm x 7.98 cm
2.7 kg
3LCD projector
Built-in Devices
Speaker
Projector
Brightness (White)
2700 lumens
Brightness (Colour)
2700 lumens
Brightness (Reduced)
1700 lumens
Contrast Ratio
3000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.47 - 1.77:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, Presentation Timer, auto power on, Quick Off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA
Carrying case, lens cover, remote control, lithium coin cell battery
1 x VGA cable
32.51 cm
23.05 cm
7.98 cm
2.7 kg
35 °C
20 - 80% (non-condensing)
