Roam: A Portable Waterproof Smart Speaker
Take incredible sound everywhere with Roam. Enjoy music, voice control, and multiroom listening at home on Wi-Fi, plus Bluetooth streaming, all-day battery life, and waterproof durability on the go.
A seamless listening experience, everywhere
Enjoy the unmatched Sonos experience on WiFi, and stream audio directly from your smartphone, tablet, or computer using Bluetooth.
Not just easy — automatic
Roam automatically connects to your WiFi network at home and pairs with your device when you're away. So the only thing you have to think about is what to play.
Tunes itself like magic
Using automatic Trueplay tuning technology, Roam adapts the sound for your surroundings and content.
Ready to soundtrack your day
The built-in rechargeable battery powers up to 10 hours of continuous playback at moderate volumes.
Refined design
Roam blends beautifully into every corner of your home, and the lightweight ergonomic design is easy to handle on the go.
Rugged durability
Featuring shock-absorbent materials and an IP67 dust and water resistance rating, Roam is primed for every type of weather and terrain.
Incredible from all sides
Place Roam upright to save surface space, or lay it horizontally for added stability. The sound adapts to the speaker's orientation for the best listening experience.
Freedom of control
Sonos app
Connect all your streaming services, discover new music on Sonos Radio, and personalize settings.
Airplay 2
Send sound directly from your iPhone, iPad, or Mac, then ask Siri to turn it up from your device.
Bluetooth
Play sound from your smartphone, tablet, or another Bluetooth-enabled device paired with the speaker.
Buttons
Just press to play, pause, skip, repeat, turn off the microphone, and manually switch to Bluetooth.
Hands-free help
Ask Amazon Alexa or Google Assistant to set timers, check the news, control your smart home devices, and more.
Seamless listening experience, everywhere
Enjoy the unmatched Sonos experience on Wi-Fi and stream directly from your smartphone, tablet, or computer using Bluetooth. Roam automatically connects to your home network and pairs with your phone when you're away. So all you have to think about is what to play. -
10 hours of play time
Powered by a built-in rechargeable battery, Roam is ready to soundtrack your day, whether you want to unwind in the garden or escape to the backwoods. -
Sound that defies expectations
Precision-engineered acoustics deliver the clarity, depth, and fullness you would expect from a much larger speaker. -
Using automatic Trueplay tuning, Roam smartly adapts to your surroundings and whatever you're listening to for sound that's astonishingly detailed and perfectly balanced. -
Refined design
Roam's slim and thoughtful form blends beautifully into your home, whilst the lightweight ergonomic design makes it easy to handle. -
Rugged durability
Solidly constructed and rated IP67, Roam is drop-resistant, waterproof up to three feet for 30 minutes, impervious to dust, and ready for any adventure.
- Sonos Roam - smart speaker - for portable use
- Product Type
- Smart speaker - for portable use
- Protection
- Weatherproof, drop-proof, dust-resistant
- Speaker Type
- 2-way - active
- Amplifier Output Power
- H
- IEEE 802.11b/g/n/ac, Bluetooth
- Intelligent Assistant
- Google Assistant, Alexa - direct
- AirPlay
- Shadow black
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable
- 6.2 cm x 6 cm x 16.8 cm
- 430 g
- Product Type
- Microphone
- Far field microphone array
- Protection
- Enclosure Colour
- Shadow black
- Design Features
- Matte finish, horizontal or vertical placing
Speaker System
- Speaker Type
- 2-way - active
- Multiroom
- Multiroom Technology
- AirPlay 2
- Amplifier
- Integrated
- Amplifier Class
- H
- IEEE 802.11b/g/n/ac, Bluetooth 5.0
- AirPlay
- Controls
- Mute, power on/off, volume, play/pause, next track, previous track, voice control
- App-Controlled
- Additional Features
- Stereo Wireless Link
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Cloud
- Voice Control
- Direct
Speaker System Details
- Driver Details
- Tweeter driver , Mid/woofer driver
- Connector Type
- USB (USB Type-C)
- Included Accessories
- USB-C to USB-A cable (1.2 m)
- IP67
- Power Source
- Battery
- Wireless Charging
- Wireless Charging Standards
- Qi
- Options
- USB charging
- Rechargeable
- Run Time (Up To)
- 10 hour(s)
- 6.2 cm
- 6 cm
- 16.8 cm
- 430 g
