SonicWALL TZ300 Secure Upgrade Plus - Advanced Edition 2yr
Quicklinx: DJSQWS00 Mfr#: 01-SSC-1742
Higher broadband demands high-speed protection. These affordable firewalls let small businesses and home offices take full advantage of high-speed broadband, without compromising the highly effective protection needed to stop cyberattacks.
Get comprehensive protection and lightning-fast performance in an entry level next-generation firewall with the SonicWall TZ Series. Designed for small networks including remote and branch offices, the TZ Series offers five different models that can be tuned to meet your specific needs. Advanced unified threat management (UTM) security, networking and management features plus optional 802.11ac Wi-Fi ensure your network and data are protected from the latest threats over wired and wireless connections.
The SonicWall TZ300 series offers an all-in-one solution that protects networks from attack. Unlike consumer grade products, the SonicWall TZ300 series firewall combines effective instrusion prevention, anti-malware and content/URL filtering with optional 802.11ac integrated wireless and broadest secure mobile platforms support for laptops, smartphones and tablets.
Move Forward Confidently
  • Parented Reassembly-Free Deep Packet Inspection (RFDPI) technology
  • Consolidated threat prevention: Cloud-based multi-engine sandboxing, anti-malware, intrusion prevention, web filtering and more
  • Feature-rich SonicOS operating system with intuitive user interface
  • Gigabit Ethernet ports
  • SSL, TLS and SSH decryption and inspection
  • Native SSL VPN secure remote access
  • Integrated 802.11ac wireless (optional)
SonicWall TZ300 - Advanced Edition - security appliance - Secure Upgrade Plus
Security appliance
External
2 x 800 MHz
RAM
1 GB
Ports Qty
5
Performance
Firewall throughput: 750 Mbps , Full Deep Packet Inspection (DPI) throughput: 100 Mbps , IPS throughput: 300 Mbps , Anti-malware throughput: 100 Mbps , Firewall throughput (IMIX): 200 Mbps , SSL inspection throughput: 45 Mbps , VPN throughput: 300 Mbps , Connection rate: 5000 connections per second
Virtual interfaces (VLANs): 25 , SSL VPN licences: 1 (maximum 50) , VPN tunnels (site-to-site): 10 , IPSec VPN clients: 1 (maximum 10) , SPI connections: 50000 , DPI connections: 50000 , Authenticated users (internal database): 150 , Single Sign-On (SSO) users: 500
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
Pricing Type
SonicWALL Secure Upgrade Plus Program (2 years option)
19 cm x 13.4 cm x 3.5 cm
730 g
Security appliance
19 cm
13.4 cm
3.5 cm
730 g
Processor / Memory / Storage
Processors Installed
2 x 800 MHz
RAM
1 GB
External
Ports Qty
5
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 3.0 - Type A , 1 x console - RJ-45
MTBF
56.1 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
Pricing Type
External power adapter
12 Watt
Power Provided
24 Watt
OS Provided
SonicOS 6.2.x
5 - 95% (non-condensing)
