With a qualified upgrade through Secure Upgrade Plus, you get an appliance designed to block today's threats. Secure Upgrade Plus now features more SonicWall network security products, as well as other specified SonicWall product lines, including secure remote access and email security. It also qualifies you for special Customer Loyalty Bundle pricing on other products.
Protect your network from the core to the perimeter with industry-validated security effectiveness and performance. The SonicWall Network Security Appliance (NSA) Mid-Range Firewall Series consolidates automated advanced threat prevention technologies in a mid-range next-generation firewall (NGFW) platform. Built on a multi-core hardware architecture featuring 10-GbE interfaces, the NSA Series scales to meet the performance demands of mid-sized networks, branch offices and distributed enterprises. Features such as application intelligence and control, real-time visualization and WLAN management provide the controls to identify, monitor and control application and user traffic across the entire network.
The SonicWall NSA3600 is ideal for branch offices and small to medium-sized corporate environments concerned about throughput capacity and performance.
Embrace Innovation
Parented Reassembly-Free Deep Packet Inspection (RFDPI) technology
On-box and cloud-based threat prevention featuring multi-engine sandboxing, anti-malware, intrusion prevention, webfiltering and more
Feature-rich SonicOS operating system with intuitive user interface
10-Gigabit Ethernet ports
Real-time TLS/SSL and SSH decryption and inspection
Application visualisation and control
Built-in wireless controller
Next-generation firewall security
A suite of tools, including intrusion prevention, gateway anti-virus, and anti-spyware plus application intelligence and control, offer granular control through application blocking, bandwidth management and more. Additional security and connectivity capabilities such as IPSec VPN, SSL VPN, content filtering, anti-spam and enforced client anti-virus make the NSA series a comprehensive and powerful all-in-one security solution. -
Multi-core architecture
Single-core and ASIC processors may have been sufficient for the design of traditional stateful firewalls. But NSA series appliances go above and beyond, with a multi-core design to help ensure that the deep packet inspection provided by the SonicWall Next-Generation Firewall can scale with your expanding organization. As many as eight cores spread the network load evenly and protect against extreme performance degradation often present in other technologies when exposed to heavy traffic conditions and malicious content. -
Deep packet inspection technology
Proprietary SonicWall RFDPI technology offers extremely high scalability and performance suitable for even the most demanding environments. RFDPI scans traffic on every port, on every protocol and in any direction to provide ultimate visibility and control. The unique design of the RFDPI engine allows it to inspect every byte of a connection - and up to hundreds of thousands of simultaneous connections - in order to categorize application traffic and protect against internal and external threats at both the application and network layer. -
Lowered complexity and cost
Along with superior power efficiency, SonicWall NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
- SonicWall NSa 3600 - Advanced Edition - security appliance - Secure Upgrade Plus
- Security appliance
- Form Factor
- Rack-mountable - 1U
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet
- Performance
- Firewall throughput: 3.4 Gbps , Threat prevention throughput: 500 Mbps , Application throughput: 1.1 Gbps , IPS throughput: 1.1 Gbps , Anti-malware throughput: 600 Mbps , Firewall throughput (IMIX): 900 Mbps , SSL throughput: 300 Mbps , VPN throughput: 1.5 Gbps , Connection rate: 20000 connections per second
- Capacity
- SPI connections: 750000 , DPI connections: 375000 , Maximum number of access points: 48 , VPN tunnels (site-to-site): 1000 , IPSec VPN connections: 50 (maximum 1000) , SSL VPN users: 2 (maximum 350) , Virtual interfaces (VLANs): 256
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
- Power
- AC 120/230 V (50/60 Hz)
- Pricing Type
- SonicWALL Secure Upgrade Plus Program (2 years option)
- 48.5 cm x 43 cm x 4.5 cm
- 6.15 kg
- Height (Rack Units)
- 1U
- 48.5 cm
- 43 cm
- 4.5 cm
- 6.15 kg
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- NAT support, VPN support, load balancing, Stateful Packet Inspection (SPI), DoS attack prevention, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, Stateful switchover (SSO), anti-spam protection, anti-malware protection, Quality of Service (QoS), RADIUS support, DHCP server, DNS proxy, DHCP relay, NetFlow, IPFIX, 2 fans
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, internal user database, XAUTH authentication
- IEEE 802.3, IEEE 802.1p
IP Telephony
- VoIP Protocols
- IP Telephony Features
- VoIP gatekeeper support, VoIP outbound bandwidth management
Communications
- Supported Flash Memory Cards
- SD Memory Card
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 2 x 10GBase-X - SFP+ , 4 x 1000Base-X - SFP (mini-GBIC) , 12 x 1000Base-T - RJ-45 , 2 x USB - Type A , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45
- MTBF
- 16.76 years
- FCC Class A certified, UL, TUV GS, C-Tick, BSMI, cUL, CB, EMC, RoHS, WEEE, ANATEL, REACH, KCC Class A, LVD, VCCI Class A, MSIP Class A, CoC, CU
- Pricing Type
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- 74.3 watt
- Power Provided
- 250 watt
- OS Provided
- SonicOS 6.5
- Shipping Weight
- 9.43 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
