The Dell SonicWALL NSA 2400 is a next-generation Unified Threat Management platform, utilizing a breakthrough multi-core hardware design with 2 cores and 6 Gigabit Ethernet interfaces to deliver real-time network protection without compromising performance. Ideal for small-to-midsize corporate and branch office environments, the NSA 2400 offers best-in-class threat prevention, rapid deployment and lowered TCO. The NSA 2400 combines high-speed intrusion prevention, file and content inspection and powerful application firewall capabilities with an extensive array of advanced network and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
Next-generation firewall security
A suite of tools, including intrusion prevention, gateway anti-virus, and anti-spyware plus application intelligence and control, offer granular control through application blocking, bandwidth management and more. Additional security and connectivity capabilities such as IPSec VPN, SSL VPN, content filtering, anti-spam and enforced client anti-virus make the NSA series a comprehensive and powerful all-in-one security solution. -
Multi-core architecture
Single-core and ASIC processors may have been sufficient for the design of traditional stateful firewalls. But NSA series appliances go above and beyond, with a multi-core design to help ensure that the deep packet inspection provided by the SonicWall Next-Generation Firewall can scale with your expanding organization. As many as eight cores spread the network load evenly and protect against extreme performance degradation often present in other technologies when exposed to heavy traffic conditions and malicious content. -
Deep packet inspection technology
Proprietary SonicWall RFDPI technology offers extremely high scalability and performance suitable for even the most demanding environments. RFDPI scans traffic on every port, on every protocol and in any direction to provide ultimate visibility and control. The unique design of the RFDPI engine allows it to inspect every byte of a connection - and up to hundreds of thousands of simultaneous connections - in order to categorize application traffic and protect against internal and external threats at both the application and network layer. -
Lowered complexity and cost
Along with superior power efficiency, SonicWall NSA series appliances lower the total cost of ownership by reducing complexity and the time necessary to configure, deploy and maintain security solutions. An intuitive GUI and powerful set-up wizards make it easy to quickly set up and fine-tune network policies, application rules, VPN connections and more.
- SonicWall NSa 2400 - security appliance - High Availability
- Security appliance
- Form Factor
- External - 1U
- RAM
- 256 MB
- Ports Qty
- 6
- Data Link Protocol
- Performance
- Firewall throughput: 450 Mbps , VPN throughput (3DES/AES): 300 Mbps , Intrusion prevention throughput: 50 Mbps , Gateway anti-virus throughput: 100 Mbps , Firewall throughput (IMIX): 225 Mbps , Connection rate: 3000 connections per second
- Capacity
- VPN client licences: 10 , VPN tunnels (site-to-site): 75 , Nodes: unlimited , Connection / user qty: 48000 , Authenticated users (internal database): 250
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2
- Included Accessories
- 512 MB CompactFlash Card
- OS Required
- Microsoft Windows 2000, Microsoft Windows Vista / XP
- Power
- AC 120/230 V (50/60 Hz)
- 43.2 cm x 26 cm x 4.4 cm
- 3.7 kg
- Height (Rack Units)
- 1U
- 43.2 cm
- 26 cm
- 4.4 cm
- 3.7 kg
Processor / Memory / Storage
- RAM
- 256 MB
- Form Factor
- External
- Ports Qty
- 6
- Connectivity Technology
- Wired
- Data Transfer Rate
- 1 Gbps
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 2, HTTP, HTTPS
- Performance
- Capacity
- Firewall protection, DHCP support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, antivirus analysis, High Availability, Intrusion Prevention System (IPS), Deep Packet Inspection (DPI), Stateful Failover, DDos attack prevention, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SHA-1, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory
- IEEE 802.1Q, X.509
IP Telephony
- VoIP Protocols
Communications
- Supported Flash Memory Cards
- CompactFlash Card
- 6 x 1000Base-T - RJ-45 , 1 x management , 2 x USB
- Power Device
- Internal power supply
- Installed Qty
- 1
- Voltage Required
- 42 Watt
- Power Provided
- 180 Watt
- OS Provided
- SonicOS Enhanced
- Software Included
- SonicWALL ViewPoint
- OS Required
- 5 °C
- 40 °C
- 10 - 90%
