Somfy TaHoma - Home Automation System
Quicklinx: DMWFWS00 Mfr#: 1811541
You and your smart home: always connected and in control with Somfy
With the new TaHoma® application, Somfy places real, condensed, technological control into your hands. Tahoma simplifes the control of multiple home devices. It’s so intuitive to use, why wait? Accessible over the internet, via a computer, smartphone or tablet, with the TaHoma® interface, you have touch control of blinds, curtains, lights, electrical equipment, heating, garage doors and gates, etc. In short, your environment moves with you, so regardless of where you are, in the house, on vacation or at work... you are always at home.
  • Control all compatible devices. Individually or in groups.
  • Provide a realtime display of the status of equipment: open or closed, on or off.
  • With the camera, you can monitor your home remotely.
My scenarios
  • Create scenarios to manage several home devices simultaneously (for instance, the "going out" scenario, which closes all blinds and roof windows, and switches off all the lights).
  • Activate your scenarios manually.
My week
  • Create a day, with scenarios which start to run at the selected time (up to 20 days possible).
  • Program a week with different days (e.g.: "work" day and "weekend" day).
My sensors
  • Combine scenarios with sensors: sunlight, temperature, opening, smoke or presence.
  • Program sending an e-mail, if the sensors detect an incident.
Somfy TaHoma - central controller - Radio Technology Somfy (RTS), io-homecontrol - white
Central controller
Power Source
Power adapter
Internet of Things (IoT) Platform
Somfy TaHoma
Max Supported Devices
200
Wireless - Radio Technology Somfy (RTS), io-homecontrol
Frequency Band
433.42 MHz, 868 - 870 MHz
White
11 cm x 7.125 cm x 2.813 cm
Central controller
Power Source
Power adapter
200
Wireless
Max Range Open Space
200 m
Frequency Band
Interfaces Details
LAN , USB , Micro-USB 2.0
USB powered, reset button
Platform
Somfy TaHoma
Network cable, remote control
White
Nominal Voltage
AC 230V
Warranty
IP20
11 cm
7.125 cm
2.813 cm
235 g
Shipping Width
15 cm
Shipping Depth
15 cm
Shipping Height
15 cm
50 °C
