Somfy Indoor Siren
Somfy Indoor Siren
Quicklinx: DMSYWS00 Mfr#: 2401494A
As soon as an intrusion has been detected the indoor siren will start it’s 110dB siren to deter uninvited people. The indoorsiren has a slim design and can be placed on any type of furniture in home.
The indoor siren has extended tamper detection: as soon as the siren is moved, it will activate instantly. The siren will go off and you will receive a push notification.
  • Loud 110dB siren to scare off uninvited people.
  • After 3 minutes the siren will stop automatically or you can stop it via the app.
  • Audible confirmation of arming and disarming.
  • The indoor siren has extended tamper detection: as soon as the siren is moved, it will activate instantly. The siren will go off and you will receive a push notification.
Fast and easy installation
  • Setup in minutes
  • Simply position the siren on a piece of furniture in your home
  • Automatic system recognition when installed.
Power supply
  • 4 D Alkaline batteries included.
  • Battery life: 2-year battery life with normal use.
What's included?
  • 1x Somfy® indoor siren
  • 4 alkaline LR20 batteriestect Indoor Siren
Somfy Protect Indoor Siren - siren
Siren
Environment
Indoor
Power Source
Wireless
Siren Sound Level
110 dB
Supported Host Device OS
iOS, Android
17.5 cm x 17.5 cm x 4.5 cm
Siren
Environment
Indoor
Power Source
Wireless
Max Range Open Space
200 m
Siren Sound Level
110 dB
Android 4.4 (KitKat) or later, Apple iOS 9 or later
Android 4.4 (KitKat) or later, iOS 9 or later
D type
Battery Included
Required Qty
4
Alkaline
Battery Lifetime
2 years
17.5 cm
17.5 cm
4.5 cm
985 g
45 °C
