Socket Bluetooth Cordless Hand Scanner 7Qi
Quicklinx: B2LRWS00 Mfr#: CX3308-1528
The CHS 7Qi is a wireless barcode scanner certified by Apple for iOS devices. Also compatible with Android and Windows smartphones and tablets,
Minimize manual data entry with the Socket CHS 7Qi, a portable 2D and 1D barcode scanner certified by Apple for the iPad, iPad mini, iPhone and iPod touch. Small, lightweight and comfortable to hold, the CHS 7Qi connects wirelessly to the smartphones and tablets and can scan barcodes printed on labels or displayed on device screens. It's ideal for retail point of sale, inventory management, and other mobile scanning applications.
Socket Cordless Hand Scanner (CHS) 7Qi - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
White
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Wireless
Wireless Connectivity
Bluetooth 2.1 EDR
2 x AAA type - Nickel Metal Hydride
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Mobile, Android, Apple iOS
3.5 cm x 12.9 cm x 4 cm
45 g
1-year warranty
White
Barcode
Interface Type
Bluetooth 2.1 EDR
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Max Working Distance
50.8 cm
Print Contrast Signal (PCS)
20%
Decode Capability
Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, GS1 DataBar, Bookland, EAN/JAN-13, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Plessey, ISSN, ITF-14
TTL Decoding
Decoded
Wireless
OK Notification
Vibration
Bluetooth 2.1 EDR
Lanyard/belt clip with retractable tether
C-Tick, EN55022, ICES-003, EN55024, Bluetooth Class 1, CISPR 22, RSS-210, FCC Part 15 C, CSA C22.2, RoHS, UL 60950-1, IEC 60950-1, IEC 60825-1, TELEC, EN 60825-1
Power adapter - external
2 x Nickel Metal Hydride - AAA type
Software
Software Included
Drivers & Utilities, SocketScan
3.5 cm
12.9 cm
4 cm
45 g
Limited warranty - 1 year
50 °C
5 - 95% (non-condensing)
Drop Specification
1.2 m to concrete
