snom 300 - SIP based IP phone
Quicklinx: 7K47WS00 Mfr#: 00001067
The basic model of the snom business telephone family, the snom 300, fulfils the most important requirements of VoIP telephony and additionally offers numerous functions that are indispensable in the business world.
For effective everyday work, the snom 300 provides all relevant office functions such as choice of trunk line, status display, group lines, the engaged option or picking up calls. A server-independent CTI now also works with the snom 300.
Main features
  • Two-line display (2x16 characters)
  • 27 keys, 7 LEDs
  • 6 programmable function keys
  • 2 Ethernet ports
  • 4 SIP registrations ("lines")
  • Headset connection
  • SIP RFC3261
  • Security: SIPS/SRTP, TLS
  • STUN, ENUM, NAT, ICE
  • Codecs: G.711, G.729A, G.723.1, G.722, G.726, GSM 6.10 (Full rate)
  • Very low energy consumption
  • Available colours: black
Display
A two-line LCD display enables the display of call information. The menu-driven user interface makes it very easy to manage numerous features. The user is guided intuitively through the phone menu via the navigation key. Additionally, more complex phone applications, call details, and configuration variations are accessible via the browser of the connected PC.
Functions
The snom 300 has six free function keys. The advantage for the user: He or she can freely decide what functions like hold, call transfer, call forward, or access mail box to map onto these keys. For other available functions please see the data sheet.
Environments
The snom 300 is designed for different environments: For use in small offices, call centers, lobbies, recreation rooms, as well as at home. With its numerous phone functions, the demands of everyday communication can be managed easily. The snom 300 has a headset connector and can be used as a tabletop phone or wall-mounted phone. Its energy consumption of 1.0-1.5 W/hr is lower than that of most competing products.
Codecs
As the snom 300 supports all of the common compression codecs such as G.729a and G.723.1, it is compatible with numerous components of other manufacturers and can be used in low-bandwidth environments. An integrated 2 Ethernet port switch enables connection to the network over an RJ-45 interface simultaneously with the PC connection!
snom 300 - VoIP phone - 3-way call capability
VoIP phone
Main Features
Integrated Ethernet switch
VoIP Protocols
SIP
Voice Codecs
G.722, G.723.1, G.729a, G.711u, G.711a, G.726, G.727
Speakerphone
Yes (digital duplex)
Caller ID
Call Services
Caller ID, Call Waiting, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
VoIP phone
Body Colour
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Menu Operation
Function Buttons
Speakerphone button, transfer button, directory button, navigator key, mute button, auto redial button
Programmable Buttons Qty
6
Volume Control
Ringer Control
Indicators
Voice message waiting indicator
Firmware Upgradable
Additional Functions
Call timer, built-in clock
Additional Features
Key lock, music on hold, built-in web server
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN)
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
TCP, TFTP, UDP, HTTP
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD)
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
100 names & numbers
Call Log Capacity
100 numbers
Display
Display Location
Base
Line Qty
2
Character Qty
16
Backlit
Headset jack / RJ-11
Power adapter
FCC Class B certified, IEC 60950, CB
Power adapter - external
Dimensions & Weight (Base)
20 cm
18.5 cm
12 cm
730 g
Resources
The following resources are available for the snom 300 - SIP based IP phone
