Smart Technologies SMASBD2075P & 3yr Warranty Plus Meeting Pro Bundle
Quicklinx: D6PMWS00 Mfr#: SBD-2075P
Anything you can show on a device, you can show on the SMART Board 2000 Pro series. This non-touch display is designed for businesses that need more than screen. It allows colleagues to participate in meetings and presentations in ways TVs can't match. Stronger ideas emerge when everyone shares their perspective. Wireless screen-sharing on the SMART Board 2000 Pro series makes it easy for colleagues to show whatever is on their iOS, Android and Microsoft devices. It's ready to go right out of the box - no apps, wires or extra hardware necessary. Even better, presentations and websites look amazing in crisp, 4K Ultra HD resolution.
  • Wireless screen-sharing
    Colleagues can show whatever is on their iOS (AirPlay), Android (Google Cast) and Microsoft devices (Miracast), and laptops on the display with a few easy taps.
  • More engagement
    Teams who are engaged contribute more. The 2000 Pro series gives every team member a chance to share their ideas on the fly.
  • 4K Ultra HD resolution
    Presentations. Videos. Web browsing. Brilliant 4K resolution ensures whatever you show on your 2000 Pro series looks its best.
SMART Board 2075 Pro 2000 Pro series - 75" Class (74.625" viewable) LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display
Diagonal Class
75"
Diagonal Size
74.625"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight full array
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
UHD Upscaling
Speaker System
2 speakers
USB
2 ports
Remote control, SMART Meeting Pro software (10 personal licences)
Voltage
205 Watt
Power Consumption Stand by
0.3 Watt
168.4 cm x 9.3 cm x 97.2 cm
31.6 kg
3-year warranty
205 Watt
Diagonal Class
75"
Diagonal Size
74.625"
Commercial Use
Yes - interactive
Series
2000 Pro series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
UHD Upscaling
168.4 cm
9.3 cm
97.2 cm
31.6 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Response Time
6.5 ms
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
Supported Video Formats
H.264, H.265, VP9, VP8
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
LAN Protocol
Fast Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a
Connector Type
2 x HDMI input , Component video input , LAN , DisplayPort , RS-232 , Audio line-in , VGA input , Audio line-in , Audio line-out , 2 x USB 2.0
TUV, IC, FCC, RoHS, WEEE, REACH
Power supply
Input Voltage
0.3 Watt
Limited warranty - 3 years
Width (Shipping)
186.4 cm
Depth (Shipping)
29.3 cm
Height (Shipping)
125.1 cm
Weight (Shipping)
49.7 kg
5 °C
35 °C
10 - 80% (non-condensing)
