Smart Technologies Smart Board 480 with V30 projector
Quicklinx: BJNZWS00 Mfr#: SB480iv2
Your SMART Board 480iv2 interactive whiteboard system combines a SMART Board 480 interactive whiteboard, a SMARTV30 projector, and other accessories. The SMARTV30 projector provides a bright high-resolution image on a short boom delivering high-definition, high-performance interactivity that is virtually shadow-free and glare-free. You can do everything you can do at your computer - open and close applications, meet with others, create new documents or edit existing ones, visit websites, play and manipulate video clips and more - just by touching the interactive surface.
The SB480iv2 system supports video and audio connections from a variety of devices including DVD and Blu-ray players, document cameras, and other high-definition sources, and can project media from these sources onto the interactive screen. All HDMI inputs are HDCP compliant.
SMART Board Interactive Whiteboard System SB480iv2 - interactive whiteboard - USB - dark grey
Interactive whiteboard
Wired - USB
Display
Projector - 1024 x 768
Dark grey
23.2 kg
Movement Detection Technology
Digital vision touch
USB bus powered
Cable Length
3 m
Linux, Microsoft Windows
23.2 kg
Dark grey
Input Device
Wired
USB
Active Area
160.5 cm x 158.6 cm
Cable Length
3 m
USB bus powered
Display
Projector
Native Resolution
1024 x 768
Image Brightness
3000 lumens
Image Contrast Ratio
3000:1
Vertical Refresh Rate
25 - 75 Hz
Horizontal Refresh Rate
15 - 72 kHz
1 x USB - 4 pin USB Type A
SMART Pen Tray, interactive pen
CSA, UL, TUV GS, C-Tick, BSMI, NOM, SABS, CB, CCC, FCC, S Mark, KC, BIS
Software Included
SMART Notebook
5 °C
35 °C
0 - 80% (non-condensing)
