The SMART kapp capture board enables you to collaborate with others in a simple but powerful way. Write and draw on the capture board just like you would a regular dry erase board. Connect a Bluetooth-enabled mobile device to the board by scanning a Quick Response (QR) code or by tapping the Near Field Communication (NFC) target to unlock the power of the SMART kapp mobile application which allows to users to capture, save and share information from the board easily. Users can even share information in real-time!
- SMART kapp 42 - interactive whiteboard - Bluetooth
- Interactive whiteboard
- Diagonal Size
- 42"
- Installation Type
- Wall mountable
- Connectivity Technology
- Wireless - Bluetooth
- 58.5 cm x 8 cm x 112 cm
- 16 kg
- Digital Vision Touch (DViT) technology, NFC support
- OS Required
- Android 4.1 (Jelly Bean) or higher, Apple iOS 7.1 or later
- 58.5 cm
- 8 cm
- 112 cm
- 16 kg
Input Device
- Wireless
- Interface
- Bluetooth
- Active Area
- 56.6 cm x 91.8 cm
Board
- Diagonal Size
- 42"
- Installation Type
- Wall mountable
- Additional Ports
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Eraser, markers, wall mounting kit
- OS Required
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
